airdoc or custom version question
Hey yall so 2007 hummer here and i want to get rid of the intake resonator. Did some research and used another thread but they say to use 3 inch pvc and 3 inch couplers and then heater hose.
Issue is the pvc 3 inch pipe connects to the throttle body no issues but the hose coming off the intake box is bigger then 3 inch and there for a big gap when the pvc pipe connects. What have you all done with a DIY? Id buy the airdoc love the look of it but being in canada and after conversion its over $200 and its a piece of pipe. I cant fine a used one so rather do a DIY and put the extra cash to something else for the H3 So anyone with info on this or to point me in the right direction that be great. 07 h3 i5 3.7 engine. |
I'd spend some time on YouTube watching videos on diy intakes.
(Post 351956)
buy an AirDoc
Cut the resonator portion off of the stock intake and cover it with a piece of aluminum or plastic, glued/riveted in place.
Use a Pringles can, old gym socks and rubber bands.
Go downtown and hang out wit da hood open and show em you style. :cool: |
(Post 351982)
Go downtown and hang out wit da hood open and show em you style. :cool: https://cimg3.ibsrv.net/gimg/www.hum...6edaf7e5a5.jpg https://cimg7.ibsrv.net/gimg/www.hum...39c7cccde2.jpg https://cimg3.ibsrv.net/gimg/www.hum...b9f5bee711.jpg I actually was kind of forced to do this, as I was chasing down a wiring harness problem that would rear it's head while driving off-road. I needed to wiggle the wiring on top of the engine, while it was running, to zero in on the problem. Unfortunately, the resonator blocked access to that entire section of the harness, and since the truck wouldn't run with the intake tube/resonator removed, I had to come up with an alternative. Already had the 1/8" plastic, the pop rivets, the silicone... Zero cost, and it fits perfectly (of course), and accomplishes pretty much what your Airdoc does. Of course, the I5 is different than the V8, but the same principals apply; get rid of the bulky restrictive resonator and provide a smoother path for the intake air, from air filter to throttle body. |
Nice removal of the intake resonator.
But you are not really solving the issue of the restriction @ the 90 degree bend where the underside is bowed up into less than 2.5". |
Originally Posted by TAINTER
(Post 352039)
But you are not really solving the issue of the restriction @ the 90 degree bend where the underside is bowed up into less than 2.5". Again, for me, it was simply a means to access/manipulate the wiring on top of the engine WHILE it was running, nothing more. |
(Post 351982)
Go downtown and hang out wit da hood open and show em you style. :cool: A helpful answer would of been nice or no comment at all. I know you have helpful answers as your have helped before.
Originally Posted by 650Hawk
(Post 352045)
True. But that existing 90 degree bend, while shorter (top to bottom), still maintains closer to the 4" in width, as opposed to the 3.5" diameter of the Airdoc. That means that there is not alot of difference in the actual cross sectional volume at that point, and that "bow" is smooth. I actually think that the "bellows" section of the stock intake right at the airbox is more of a "flow" hindrance than the smooth bowed up portion at the elbow; The Airdoc certainly eliminates that bellow, although I'm not sure that's the best idea, as the bellow allows more movement between the engine in it's rubber motor mounts vs the fixed airbox than a short silicone coupler allows.
Again, for me, it was simply a means to access/manipulate the wiring on top of the engine WHILE it was running, nothing more. I was hopeing there was a different pipe or brand that sold the correct pipe or a really good DIY or part list and items to get. Rather put the $$$ i save on a pipe and put towards something else useful on the H3 but would really like to get rid of that resonator :) Common guys and gals i know yall with the I5 have done something besides the air doc :) |
