Avic-900
I have the pioneer 9010bt as well, I have a sirius radio hooked up to it, but my H3 is also manual, and the accessories for the radio are tucked in under the dash, through the shifter boot. Also, my GPS antenna / sirius antenna were able to fit under the trim for the marker lights for a clean install. I will update with pics shortly.
Thanks. After a long debate I opted for the Pionieer Avic N-5 as it needs a single slot only and the display will be higher if I put it in the upper slot. The other slot should provide space for the XM and Bluetooth unit. I will start to work on it next weekend when I have all pieces.
What adapter did you use to retain your Onstar etc.
PostRelease
06-17-2009 03:24 PM
PostRelease
06-17-2009 03:24 PM
PostRelease
06-17-2009 03:24 PM
PostRelease
06-17-2009 03:24 PM
