AC/Heater Issue. Please Help
Old Dec 11, 2011 | 11:33 AM
justanotherhemi's Avatar
Default AC/Heater Issue. Please Help
Hello guys. It finally started getting cold enough in South Texas to were the heater is needed. I tried moving the Temp adjustment **** only to find out that my Hummer goes from really cold to really hot with the slightest movement of the ****. Has anyone experienced this before? Is it a **** issue? AC/Heater issue? Please help
BTW the Hummer is a 2007 Adv pkg with 43,xxx miles if it helps
Thanks in advanced for your replies
Old Dec 11, 2011 | 01:05 PM
mthoodh3's Avatar
There are others including myself who have experienced this issue as well. Here is one thread about this problem, i know there are others you might want to search for. https://www.hummerforums.com/forum/h...t=hvac+control
In my case the temperature problem didnt appear until i ran the "temp control calibration" sequence with hopes of fixing a different a/c problem. The calibration process seemed to cycle through some modes with ***** flashing like it actually calibrated something. all it did was give me boiling heat when the **** was only 1 click to the right. I refused to believe i broke anything though just by pressing a few buttons and i wasn't going to take it to a dealership for them to rip me off so i let it be since it was the summer anyway. Well to make a long story short after a few months of maybe turning the ***** here and there it works perfectly again. Good luck with yours.
Old Dec 11, 2011 | 07:56 PM
krlemoine's Avatar
Same problem with mine. Took it to the dealership they replaced the control module under warranty...
Old Dec 20, 2011 | 04:59 PM
bigdog100's Avatar
I had the same problem, then when i put the Temp **** all the way over I hear 3 thumping noises and the hot is still cold. I have no heat now. Is the control module the actual **** or is it a vaccum line or something like that?
Old Jul 8, 2013 | 06:54 AM
Peng's Avatar
I got the same problem, i got rid of the noise by disconnecting a wire that i believe the power for the fan, but my temperature is stuck in cold, no hot air anymore. Did you fix your problem?
Old Jul 8, 2013 | 07:21 AM
happythree's Avatar
you might want to spend some time reading past posts on the forum.
the last entry here was 2 yrs ago, go back some more and read away!
supsam86
19
Jul 20, 2015 09:22 AM
jvorpahl
Dec 22, 2012 10:46 PM
H3LUX
Mar 31, 2012 11:51 PM
photo_h3
Dec 3, 2009 08:11 AM
TXH2SUT
Apr 30, 2009 07:49 PM
