AC Compressor Clutch Question
Old 09-02-2015, 02:06 PM
HawaiianH3's Avatar
Default AC Compressor Clutch Question
Aloha folks,
Ok so my compressor clutch **** the bed yesterday with all the insane heat and humidity we have been having here.
Symptom: when I started the 3 (vehicle warm from driving) a very loud grinding noise from the engine. After inspecting the clutch was engaged but black grease was seen all on the outer rim of the clutch. It had even flung a minute amount on the skid plate bellow.
When I got home i shot a **** load of WD40 (miracle lube) all over the clutch. This seem to take away the sound.
Conclusion: The clutch is bad and lets hope it didnt screw up the compressor.
Question: I have looked high and low and can not find just the clutch component for our vehicle. I did however find it for the the 2010 H3. Maybe they changed the compressor that year. Anybody have any ideas?
Thank you.
Old 09-09-2015, 02:33 PM
mr.spooky's Avatar
I would just change the whole thing. you gotta get the whole thing out anyway.... I was in the same situation as you and just decided to change the whole thing. Because the clutch is attached to the compressor, I was nervous that it caused damage to it.... I DID NOT change the accumulator or the other thing they suggest you change. If the compressor is working, I dont see a need to. over all, its a pretty easy, straight forward job, just a little time consuming.
Old 04-22-2018, 04:00 AM
HawaiianH3's Avatar
Default 3 years and still pumping cold!
TY Mr. SPOOKY for the tips! Changed the entire compressor and that's all. She still blowing cold as ever!!
Waelhilal
09-16-2014 08:26 AM
08xcab
11-08-2011 08:56 AM
HUMMERHOUSTON
07-10-2008 11:28 AM
AussieH3
01-09-2008 03:52 AM
HummerGuy
18
05-05-2007 02:27 AM
Quick Reply: AC Compressor Clutch Question
