2007 Hummer H3 wont shift from second to third
Old 11-02-2019, 10:23 AM
Chris Catino's Avatar
Default 2007 Hummer H3 wont shift from second to third
2007 hummer h3 122k miles, wont shift from 2nd to 3rd, replaced tranny with a used one and its doing the same exact thing! if there reprogram or something that im missing? 2 tranny's doing the same exact thing? help!
Old 11-02-2019, 02:30 PM
maybe it's an electrical issue with the harness or connector. you would have to connect a scanner that can interface with the transmission to see if she is shifting or if it can activate your shift solenoids.
Old 11-02-2019, 05:33 PM
Seriously, the transmission was not shifting from 2nd to 3rd, so you replaced the transmission?
Old 11-03-2019, 09:48 AM
wpage's Avatar
Ouch, bet that hurt...
Next time ask here first for good resources.
Old 11-04-2019, 11:39 AM
The 2007 H3 Auto Trans is controlled by the PCM. The PCM tells it when to shift and to what gear. You likely have an electrical issue.
Scan it for codes and post whatever codes it may have stored here.
Fito53jr
08-14-2018 08:42 AM
Glassguru
03-27-2018 09:49 AM
blharty
07-18-2016 08:28 AM
Zeppelin
06-20-2016 04:07 PM
rsm688
11-06-2014 05:28 AM
Quick Reply: 2007 Hummer H3 wont shift from second to third
