2009 5 cyl. fuel pressure spec?
Old Oct 13, 2015 | 07:51 PM
rja's Avatar
rja
Default 2009 5 cyl. fuel pressure spec?
I'm helping a friend diagnose a no start condition. Ignition is good. Looking at the fuel system now. What is the spec pressure supposed to be? Thanks for helping the new guy. I searched the forum and couldn't come up with it.
Old Oct 13, 2015 | 08:56 PM
skeeter's Avatar
I would check the passlock first. they are notorious for acting up
Old Oct 14, 2015 | 07:17 AM
rja's Avatar
rja
Thanks Skeeter. I've thought about the Passlock system issue myself. The owner feels that it is a fuel pump issue so I'm basically eliminating issues one at a time. I would still like to know what the spec is for fuel pressure so a pressure issue can be eliminated. Thanks guys.
Old Oct 14, 2015 | 08:24 AM
Fuel pressure for the I5s should be within 10% of 55 PSI. Anything outside that range could cause problems.
I would think passlock as well.
Old Oct 15, 2015 | 09:41 PM
rja's Avatar
rja
I've found out that the fuel pump does not run at all. I checked it with a gauge but it's pretty obvious that it makes no noise what so ever. I would like to check the relay but I can't seem to find the location in the fuse block under the hood. I don't see any relays marked as being "fuel pump" like most vehicles. Do you guys know where it is on a '09 with the in line 5 cyl engine? Thanks again.
bowtieturninghummerguy?
Nov 21, 2012 10:53 PM
markushp
Jul 17, 2009 02:22 PM
SlvrCrk98
Jul 8, 2009 12:50 PM
photo_h3
Apr 11, 2009 10:04 AM
moteaux
Aug 30, 2007 08:45 AM
