2008 hummer h3 wiper squirting
Every time I turn right the left/drivers side wiper squirts a tiny bit of fluid out. Checked tubing it doesn't look squeezed by anything. Help
I was gonna go somewhere with this, but I decided I better not......
Newton's laws: The driver side windshield sprayer has the longer hose. Overfilled wiper fluid reservoir + right turn = inertia to the fluid in that hose causing some to drip out. :)
Lay on the sprayer a bunch of times, then see if that does anything regarding what you see. Yes they drip some times. If it is actually spraying, I got no idea. |
Just using the washers and taking a turn will make them to this.
Not an issue. |
