2008 Alpha Making Loud front right clunk when turning sharp
Installed the new encoder motor with the vehicle in neutral and the tcase in neutral. No change at all. The encoder
motor and tcase still dont seem to line up? Could the TCCM be bad? It seems to rotate the encoder motor properly and the correct amount, they just don’t line up! Could something in the tcase be bent causing the shaft to be slightly off? Never been inside of one of these
Be aware there are 2 different types of TCCMs based upon which T Case you have (ie.. the standard or low range off road) so confirm that if you order one.
But he said the previous owner rebuilt the transfer case. He could have use a plastic fork.
Also sorry Doc, but heck yes some of them do!
Had one in my 2008 H3 Alpha Offroad - Mr. Blue.
Plenty of people have reported plastic shift forks in 07, 08 and even some 09 H3/H3T with adventure/OffRoad pakages.
Just replaced the plastic fork in my '09. Transfer case was dated 06/06/2006. There were no indications that the transfer case had been replaced; the gasket between T case & transmission was as hard as a rock & had to be scraped off (in pieces), all of the wiring clips and fasteners were intact. My problem was a lack of 4WD lock.
By opening the transfer case and looking inside or looking closely at the T case for a build date. I looked years ago if GM had any VIN# info
about that and I could not find anything.
It doesn't matter if everything works properly. I assume mine has one and it works just like it is supposed to, zero issues.
