2006 vrs. 2008 - Hummer Forums - Enthusiast Forum for Hummer Owners
Reply
Thread Tools Search this Thread
Old 11-14-2017, 01:05 PM
Default 2006 vrs. 2008
Hello
i am looking to get an H3 Need something very snow worthy for my girl. 06 much more affordable than. 08 but have been told 06. I5 Much more louder almost irritating then 08. I did drive an 08. Was nice and quiet. Is it true Also any other reason to go with 08 ?
Want something very soon snows flying
thanks in advance for ALL responses
Old 11-14-2017, 01:26 PM
I do not know where you got your information, but the sound level of a 3.5 L52 I5 vs 3.7 LLR I5 GM Atlas motors identical in design except for the larger bore size in the 3.7L would sound as near identical as is possible to compare as they have essentially the same exhaust.
The 3.7L built after April 1, 2006 (all of them in the 2008) will have the corrected hardened valve seats in its head. That alone is the reason to look for a 2008 vs 2006. Many of the 2006s have had their original heads replaced now, so that would be less of a current issue.
If you do look at 2006s, you want one with a serial # higher than 287591, the build date should be after Nov. 2006 to rule out a bad first design head flaw if you do not have confirmation that the truck has a newer head.
Old 11-14-2017, 03:52 PM
My info Must have been from someone with a bad exhaust............ THANK YOU very much though now I know what to look for if I do get her an 06 for build date after Nov 06 and SERIAL # or ask about replaced head. Best regards... Jaws .
Old 11-14-2017, 04:21 PM
Personally I would go 07 or newer. Stay with 3.7 or 5.3 (08 or newer) if funds allowed. 3.7 has slightly more power than 3.5.
Old 11-14-2017, 05:00 PM
a0128's Avatar
From an interior stand point the 2008 had a redesigned driver's side window switch setup. Much improved over the 2006 / 2007.
Old 11-14-2017, 06:20 PM
Quote:
Some 07s had the arm rest and switches that were forward as well. My 07 did not so I changed the door panels. They are much easier to see and use now.
Old 11-16-2017, 12:39 PM
Bunger's Avatar
Quote:
Yes, that was a mid year change.
My 07 has the controls on the slant.
Old 11-21-2017, 07:20 PM
norinco3264's Avatar
My 2006 H3's VIN falls within the range of bad cylinder heads, and hasn't been replaced. 94,000 miles and have seen a cylinder 5 misfire code approx 5 times. She has a terrible idle in the winter (replaced coil packs, new air filter, camshaft position sensors, super clean throttle body, stinger terminals, MAF sensor cleaned etc). Header bolts look ok. Under powered and the arm rest controls are miserable! Made for T-Rex!! But, I still love her... she's never left me stranded.
Reply
Thread Thread Starter Forum Replies Last Post
H3 2006 vrs 2008 Aaajaws Hummer H2 2 11-14-2017 11:58 AM
2006 - 2008 Side Mirrors Beast05 General Hummer Talk 12 10-13-2011 12:42 PM
2006 Door Panel Replacement with a 2007 or 2008 hummer3 Hummer H3 6 09-12-2009 02:07 AM
OFF ROAD: Country Roads (THCI) 7/24/2008 - 7/26/2008 rhill20 Meets, Events, and Shows 39 07-14-2008 04:50 PM
have 2006, advantage of 2008 version H3? moho Hummer H3 17 04-17-2008 11:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
