2006 Leaf Spring Replacement
My driver side leaf spring broke at the eyelet Sunday night so I'll be purchasing two OEM springs tonight and installing them this weekend.
Will I be removing the fuel tank? It's been raining and I haven't had a chance to crawl underneath to look things over, but from what I can see, there is a protective plate of some sort on the driver side that will prevent removal of the forward leaf spring bolt.
The tank does not need to be removed, just the skid plate that covers the tank. There is a pocket molded into the plastic fuel tank for accessing the leaf spring bolt.
We used a wafer wheel to cut through the front bolt of each leaf spring. The right side bolt rusted to the spring, but not the frame. The rear bolts broke loose but I decided to replace those as well.
Part of me thinks I should have put never-seize on the shank of the replacement bolts.
So my 2006 H3 passenger leaf spring snapped where it wraps around front "eye bolt" or hanger thingy. Right rear wheel is now set back about 3" further than normal and tire is just barely rubbing the mudflap.
I'm tempted to replace both leaf spring stacks myself, how bad of job is it? Should I just go with OEM or is there a better option? Will they line back up or do I have to worry about alignment? I'm fairly competent mechanically but would it be better to just tale it to a shop?
Any help would be greatly appreciated.
Thanks,
Kevin
Thanks,
Kevin
