2006 hummer h3 radio removal
I am removing the factory radio from my 2006 hummer h3 and I can't figure out how to unplug the antenna ... at least I think it's the antenna. I have removed radios from other vehicles and to unplug the antenna you just pulled on this cable and it just pulled out ... but I can't get this one unplugged ... is there a trick to unplugging this antenna? I need help!
Brad
Brad
The actual cable jacket is black. If this is what you are dealing with, then yes, you just pull straight out.
If the connector is square green and the wire is small then that is the GPS antenna and it has a clip to release first
jobenshain
01-24-2014 11:07 PM
