12 V Air Compressor Reviews..????
Old 08-30-2012, 05:54 PM
ozark1's Avatar
Default 12 V Air Compressor Reviews..????
Going to buy one for use in my H3 and F-150. What has been a good product..and ..what should I stay away from...thanks..JV..
Old 08-30-2012, 07:02 PM
wfturner's Avatar
I bought this model years ago and it is a capable compressor. I have it hard wired to an electrical PTO on the front of the truck. This unit draws near 40 amps
I easily takes my 33" back to 38 LB from 15 PSI in very little time
Q Industries SuperFlow Twin Cylinder Air Compressor — 12 Volt, 120 PSI, Model MV89G | 2 - 9 CFM| Northern Tool + Equipment
Old 08-30-2012, 08:22 PM
ozark1's Avatar
I can't really go the Hard Wired route. I sometimes use the F-150..and I have a 5.9 RT Durango..in addition to the H3..And..sometimes my son takes one..so ..I need a good portable unit...Suggestions...??..thanks..JV
Old 08-30-2012, 09:16 PM
Xlr8n's Avatar
2 nice, inexpensive portable units are discussed in this thread (from a Jeep forum I've been on for many years): Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures - JeepForum.com
I used the Harbor Freight compressor for a couple years, which I had mounted under the hood of my TJ. Held up and worked well. It is very, very similar in design and construction to one of the VIAir pumps which sells for 300 bucks.
Both of the pumps outlined in that thread would serve your needs very well.
The unit wfturner linked above does have the quick battery terminals as well.
Old 08-30-2012, 09:46 PM
wfturner's Avatar
Yes, I am sorry, but when I stated hard wire, in reality, I use a dedicated 50 AMP plug on the front of my truck, to plug in the compressor, which has same plug.
It is very portable and comes with soft case too.
I did my home work and almost all small units used the cigarette lighter which can only run
smaller amp draw units.
Those work fine, but you wait a long time to air up a 33" tire times four.
Xrl8n is correct in the the name for the connectors "quick battery terminals"
and they can handle high amp draws
Under the hood compressor is way cool
Good luck
The connectors I am speaking about . . .
Amazon Amazon
Old 08-31-2012, 04:50 PM
Harbor Freight model here also. It's pretty quick and won't break the bank. Has alligator clips for direct battery hook up.
Old 02-11-2013, 04:05 AM
hayabura's Avatar
thank you
air compressor
Old 02-11-2013, 12:03 PM
bflank's Avatar
Bought Q Industries MV50 SuperFlow High-Volume 12-Volt Air Compressor from Amazon for a decent price and seems to work well. Just my opinion, if a 12V compressor has a cigarette lighter plug it probably doesn't have enough capacity to do the job. This compressor has gator clamps to hook directly to the battery.
Old 02-11-2013, 09:37 PM
rsc's Avatar
rsc
rsc is offline
The air compressor from SLIME (walmart bought) is pretty good for a cigarette lighter plug model. Much better than the other's that moved over to the wife's Liberty. It still isn't as nice as having your own air compressor though.
Old 02-11-2013, 09:39 PM
Happy Hummer's Avatar
HF also.
Chris
scuba namena
12-03-2009 09:37 AM
skeeet
04-09-2009 05:35 AM
Sugardaddy
09-12-2006 06:38 AM
Rayvyn
11-24-2005 09:25 PM
Quick Reply: 12 V Air Compressor Reviews..????
