07 H3 Wiper problem
Old 02-25-2013, 09:19 AM
rayzorback's Avatar
Default 07 H3 Wiper problem
Please help. I've been reading everything I can find, but haven't come across a fix yet. My wife's 2007 H3 front wipers have gone crazy. They come on momentarily when the ignition is turned on. The "Mist" setting operates but the wipers stop all over the windshield (Do not park themselves in the correct position) they also work fine on High, but again won't "Park" themselves correctly. I have replaced the wiper motor and nothing changed. Is it the BCM (Body control module) or the Multi-function wiper/washer/turn signal/cruise control switch or something else.
Thanks in advance.
Old 04-28-2013, 10:30 AM
woodeye's Avatar
Im have the same.issues,no slow ,no intermittent only high.speed,but this also stops after a few swipes ... Cannot find fix anywhere on line.
Somebody has the answer
I've tryed pulling fuse to.bcm .waited few mins ,reinstalled fuse Ng. Tryed removing neg battery terminal. Waited 5 min,reattached NG.
Very frustrating..really don't.want.to.go.to.stealer lol
Woodeye
Old 04-28-2013, 11:21 AM
woodeye's Avatar
Woodeye
Old 04-28-2013, 12:47 PM
pool_shark's Avatar
I had that problem. There was a problem with the wiper transmission or something to that effect.
My extended warranty covered it.
Old 04-29-2013, 07:48 AM
rayzorback's Avatar
Smile Good News: Wipers Fixed
I finally got the Wiper problem fixed on my '07 H3 after much agony.
Here is the history: I replaced the wiper motor, No change.
Replaced the column switch, no change.
Replaced the BCM, no change.
I gave up and took it to the Dealer and they replaced the underhood FUSE BOX that had a short or something wrong with it.
Another Wiper motor was required as the bad FUSE BOX ruined the new wiper motor.
In short, the problem as a Bad Fuse Box. Go figure. All is well now.
MJN
01-05-2015 01:55 PM
HumV
11-06-2014 11:31 AM
carlosorama
12-06-2008 09:18 AM
steves05h2t
06-10-2008 11:44 PM
pduffy
05-03-2008 05:51 AM
Quick Reply: 07 H3 Wiper problem
