'07 H3 - Strange Noise when put in Gear!!
Old 08-03-2012, 04:07 PM
pierbranch's Avatar
Default '07 H3 - Strange Noise when put in Gear!!
I've done several searches and haven't found an exact description, forgive me if I'm duplicating a thread. 2007 H3, automatic tranny. Strange noise, kind of a whining, maybe even slight grinding but not a harsh grinding sound only when I engage any gear even though not moving. Put it in park or nuetral gets quiet, only starts when engaged. Going down the road it's kind of a high pitch whine and gets better as rpm's back off.... No shifting issues/popping noises/slipping, no idiot lights come on. Changed Transfer Case oil just to make sure, it wasn't low, dirty maybe so new fluid should only help but didn't take noise away. Tranny still feels strong..... thought mabye differentials or axles etc... but does it even sitting still with brakes on, and only when put into gear. Hope that description is good enough. Other than this I've had no issues with this vehicle, been a pleasure to drive for last 3 years... has about 73k on it now. Any help greatly appreciated!
Old 08-03-2012, 07:32 PM
2wheelmonster's Avatar
Mine is doing this as well, I inflated the tires to the proper level, that seemed to help some. I wonder if it's something with the throttle body control
Old 08-07-2012, 11:56 AM
Autopilot's Avatar
My front differential was making a whining noise and had a slight grind when I was stopping and taking off.
Old 08-15-2012, 07:42 PM
pierbranch's Avatar
Default TSB found
http://www.ownersite.com/tsb/tsbs.cfm/2009/HUMMER/H3/
Finally found this, Link above mentions a Technical Service Bulletin, referring to a bearing that goes bad in the torque converter. Guess replacing the converter is next move. Sux...but is what it is.
force0009
02-13-2013 01:45 PM
Cashville
09-04-2011 10:10 AM
H3DONIST
05-25-2010 03:15 PM
canchas
11-03-2008 10:36 PM
h22005
02-11-2008 03:19 PM
Quick Reply: '07 H3 - Strange Noise when put in Gear!!
