06 vs 08 Door Panel/Arm rest
Old Apr 21, 2008 | 02:08 PM
heavyD's Avatar
Default 06 vs 08 Door Panel/Arm rest
The other day I seen a door panel on a 08 and noticed that its not much different then my 06 except for the design and where the electrical stuff is located on the armrest. My question is, can I put an 08 door panel or just the armrest on my 06. I have studied all the components and all the part numbers match up except for the door panel itself. I am pretty sure that I am not the first person to ask this question, since the armrest design on the H3 was a poor one at first. Thanks for any and all help on this.
Old Apr 21, 2008 | 03:03 PM
Hummer Guy's Avatar
Default RE: 06 vs 08 Door Panel/Arm rest
You can put on the new door panel, but you will also need to extend the wiring with some sort of jumper to reach the new location. New door panel and a jumper should be all you need.(I don't know the part #s...)
Old Apr 21, 2008 | 06:23 PM
heavyD's Avatar
Thanks for the info Brian, I seen in some previous post where you posted pictures, helped a lot, as I was pricing the door panel switch out I noticed that the connection wire was the same from 06-08, is the 08 one longer and have the same connectors on it? Are the back door panels the same?
-Darrin
Old Apr 21, 2008 | 06:46 PM
Hummer Guy's Avatar
Rear door panels did not change. If there's a different part number for 08, I'd go with that - the connectors should be the same.
Old Apr 22, 2008 | 06:59 AM
Trey124's Avatar
Keep us posted and post some pics when you get the new door panel put on.
Old Apr 22, 2008 | 06:04 PM
heavyD's Avatar
I sure will, thanks for all the help on this, any more info is greatly appreciated.
-Darrin
Old Apr 27, 2008 | 07:54 PM
heavyD's Avatar
I was talking to a dealer Friday about ordering the 08 door panel, they told me I need a vin # to order the correct interior color, so I am needing some help with this. I have a black and tan interior, and need a vin # for a 08 or late 07 with the same interior color. I actually think its called ebony and cashmere. Can anyone help me out with this.
H2Miami
Oct 20, 2014 12:21 PM
jetboy
May 27, 2014 01:42 PM
mulh222
Sep 29, 2013 09:51 PM
Man1nboat
Jun 25, 2013 11:20 AM
RaYoSeKiZ
Jun 29, 2010 09:20 AM
