06 H3 3.5 Transmission removal
Hey I was wondering if anyone could tell me how to remove the tranny from my 06 H3....I have everything unhooked and the T-Case already removed, but I can not get the transmission loose from the engine block. I have removed the 11 bolts from the bell housing and can get it to slip loose a little on the passenger side but the drivers side seems hung. I'm not sure how else to go about it other then maybe needing to unbolt the starter? I can't see anywhere else I would be hung up other then in that area, but the starter seems to be out of the way of the transmission. I am not sure on how to unbolt the torque converter so I was just going to slip the tranny out and then figure that problem out later. If anyone has any idea or tips on getting it out I really appreciate it.
Jeesh, nothing?
Originally Posted by HawaiianH3
(Post 329844)
Jeesh, nothing?
starter bolt into bellhousing?
Perhaps...
Did u remove the dipstick ? And the torque converter isn't bolted on it just slips on
(Post 329848)
Yep, nothing in FOUR YEARS! Please do not dig up old as dirt threads, absolutely no reason for it.
Oh oy!! Somebody's got some "splaining" to do!!
Here comes the complaining! GOO GOO
Took it to Aamaco 5 years ago had a reman installed. 3year 100k warranty figured it was better then waiting for a answer on here.
And I'm sure Aamco don't get mad at you for bringing up old stuff buwahahahah!
