7.5 amp Fuses and Fuse Block
Sorry folks if I am posting this in the wron place. No that up to speed on how to post. If I can get the help I need I"ll get out of your hair
My ride is a 05 SUT, it's my baby. I have no back up lights, my fault, I arched a wire finish my installation of additional back up lights. Prior to the short all lights worked fine. Have found the 20 amp fuse under the hood fuse box PU/LP or similar. On line in a fuse list I found a back up fuse in C 3 or C-5. This is a 7.5 amp fuse, there just happens to be a spare 7.5 amp fuse on the fuse panel cover located on the left side, end of dash board. Proble is the is no 7.5 fuse located in this fuse bloke, or the one by the brake peddle or under the hood, somewhere I read it was in the instrument panel upper fuse block. Where in the heck is the located? If someone could tell me where to find the location of this darn fuse I would be thankful
Beards
Beards
Welcome to HF.
I MOVED this because tech questions do not go in the New Member Section. Tech questions should be asked in the vehicle section for whatever Hummer you have. Its tricky, but H2 SUT questions should go in the ..........
............... wait for it..............
suprise.............. the H2 SUT section.
Ask it ONCE and wait for answers, do not repeatedly post the same question.
While waiting, try a GOOGLE SEARCH and SEARCH here,
See what happens when you Google "Hummer H2 Fuse Block".
The first thing that comes up after images of the fuse block diagrams is....
Interior Fuse Box Location: 2003-2009 Hummer H2 - CarCareKiosk
https://www.carcarekiosk.com/video/2...terior/replace
Click the blue link.
JerseyJoe
07-20-2017 12:08 PM
juicebox123
04-23-2016 04:55 PM
