2005 H2 transmission issues
Old 05-25-2012, 01:27 PM
ticknlo's Avatar
Default 2005 H2 transmission issues
125k and 3rd gear in tranny went out. Took it to a dealership...3600 dollars later had a rebuilt 100k warranty tranny in place. Now I have this annoying rattle from underneath. Happens when I take off mostly but you can put it in neutral and it stops. Got under there today and looks like there is a metal plate between the bell housing and the motor that might be the culprit. Its not loose but you and flip it with the end of your finger and it makes that type sound. Anyone had any dealings with such?
btw Im new to the site but looks like a great set up. Thank you
Old 09-22-2013, 10:18 AM
rlmoralez's Avatar
Is it round???? What is this thing for?? I have a small leak there.
Old 09-22-2013, 02:54 PM
greg260's Avatar
must be missing a bolt in the lower half of the bell housing that holds it in place. It should not move enough to make a noise if all the bolts are installed.
Metallist
05-06-2018 12:42 PM
Hummer Hog
07-18-2015 11:02 PM
daiglesbagels
08-31-2014 08:57 AM
Nate2106
16
08-18-2014 05:39 PM
Andreas_Sweden
03-30-2012 03:12 PM
Quick Reply: 2005 H2 transmission issues
