Wiring harness hanging down in tire well
Hi i would like to ask is there any pictures of where the wiring harness is supposed to lay part of mine is in my wheel well and Im not sure how its supposed to go
https://cimg6.ibsrv.net/gimg/www.hum...485797a43d.jpg https://cimg8.ibsrv.net/gimg/www.hum...511c32a708.jpg |
Surprised that nobody responded to this. Did you figure it out?
If not, let me help. Looks to me from the photos like it *maybe* came out of the 1st front black plastic loom clip and is barely sitting in the 2nd one? It is not good where it is, and can be subject to getting hit by rocks. So you MUST fix this. Put it back in its holders, and then since it want to come out, use use plastic zipties to secure it in the holders so that does not happen again. If too short to fit into the 1st plastic clip, just ziptie it to the rest of the metal lines sitting on the frame. No problem. Easy peasy fix. |
mine is close to the same location (a little higher on the frame at the body mount) and pretty sure that is where it was from the dealer.
mine runs alongside of the metal lines To the left in the pic the harness clip looks to have come loose on yours Neal |
