-   Hummer H2 (https://www.hummerforums.com/forum/hummer-h2-8/)
-   -   Wire use? (https://www.hummerforums.com/forum/hummer-h2-8/wire-use-46797/)
PGI Conch Mar 22, 2023 01:09 PM
Wire use?
Anyone know what the purple wire/connector coming out from the Fuse Box goes to?
https://cimg3.ibsrv.net/gimg/www.hum...8db983bc2b.jpg
hummerz Mar 22, 2023 04:57 PM
Looks AM to me. You can trace it, or cut it and see what happens.
PGI Conch Mar 22, 2023 05:30 PM
Perhaps, but there arent any aftermarket items on the vehicle except PO changed out the wheels for some AM wheels (one of the reasons we purchased this one, neither PO's "personalized" it with add ons). The plastic wire protector was coming out of that area before the dealer replaced the entire fuse block with a new GM product. Now that wire/connector are more apparent than just seeing the plastic protector. Just thought someone may be familiar with it before I go pulling the shroud off to see why the dealership didn't ensure it was put back and attached properly.
hummerz Mar 22, 2023 06:15 PM
OEM wiring is solid color or with a straight line tracer(different color stripe on the wire). That wire appears to have a spiral tracer(purple with black) and also appears damaged/separated internally.
OEM wiring with tracers:
https://cimg8.ibsrv.net/gimg/www.hum...ffe83916f3.jpg
Your Wire:
https://cimg8.ibsrv.net/gimg/www.hum...6256b1e5d8.jpg
PGI Conch Mar 22, 2023 06:32 PM
Your Wire:
Gotcha. I will be finding the solution sometime in the next week or so when I pull the cover.
hummerz Mar 22, 2023 06:40 PM
Just trace where the wire goes. Could be for a tracking device?
