winshield wiper problems
Old 10-15-2005, 08:27 PM
c5vette's Avatar
Default winshield wiper problems
04 wiper come on by themselves-befoe I go to Mr Badwrench , any suggestion fo a fix?
Old 10-16-2005, 02:47 PM
shortbus's Avatar
Default RE: winshield wiper problems
move to hawaii. it rains a lot there, for part of the day anyway, so you'll be happy they come on by themselves. otherwise, no idea, but probably something loose in the switch on the column.
Old 10-26-2005, 05:58 PM
Patrick's Avatar
Administrator
i think that it would have to be a short, or (the better case) the switch.
Old 10-26-2005, 06:09 PM
efrainl956's Avatar
I think there's some type of modulator near the wiper motor that's shorting out and makes it turn on or go wild. I'll research it and post again later.
Old 10-26-2005, 08:57 PM
efrainl956's Avatar
Most likely the contacts inside the motor case have become corroded since the motor is not waterproof. Usually happens if it's rained a lot or your H2 has really been submerged! Once the contacts become corroded, they short out and they start going by themselves. Also happens if the washer fluid runs down the wiper motor, too. There might be a service bulletin out on this.[sm=signs003.gif]
Old 10-28-2005, 03:48 PM
Patrick's Avatar
Administrator
what do they do for the TSB?
Old 01-27-2008, 05:21 PM
My truck does the same thing!! I've noticed that the dealer spilled plenty of wiper fluid down the side of the continer. Also, this started happening during the recent rain we've had here in Los Angeles. Did anyone figure out what the problem was. If so,what modular do I need to change?[:@]
Old 01-28-2008, 12:18 PM
Wiper module........Turns on and off by itself and at different speed rates.
Old 01-28-2008, 12:19 PM
Sorry it's located on the wiper transmission.
Old 01-28-2008, 05:01 PM
i have the same problem i was told there a problem with the wiper transmition
Quick Reply: winshield wiper problems
