Wheel Dragging
Sorry my bad. It was 2004 H2 with 140k miles on the clock. Offroading in the dry sand dunes. I did crawl underneath and check the connection,seems to look ok but I will attemp with your suggestion this evening. 2 days back the actuator did responding but only half a click whenever i'd try to select 4AWD whilst compare to the 4low or 4high it produce a full click sound. I am assuming actuator gear might loosen or broken.
Clicking as u push buttons
When I shift my H2, from any section you can hear the T-cast shifter click, and I roll it back in forth to make sure it in locked AWD.
i rotate the different selections every month to assure the shifter works, after last year I had to have Hummer replace the Transfer case shifter $645.00, after the service 4 drive, light showed up, and stayed in AWD, made hauling boat out at low tide challenging on the Green slime.....
Update.
T-cast shifter click only between 4HI to 4LOW but won't click on 4AWD. I decided to remove the actuator and tried to manual release it by turning counter clockwise the shifter shaft on the T-Case in attempt to release it back to 4AWD but unable to shift it back to 4AWD offcourse with the gear in Neutral. What actually wrong here,The actuator motor or T-Case?
Whenever I try to unlocked it manually I felt a resistance. It was free move for a half turn at first and then it felt like there is a spring attached. I couldn't get full turn due to the resistance. Is that normal?
And also, 04 H2 T-Case actuator motor is identical with 04 FORD F150 isn'n it? By the look of it triangle shaft shape,it look identical.
Any help is appreciated
Update.
I removed the actuator and try to shift it just to see the respond of the actuator itself. Guess what,it moved corresponding to the gear selection. Now I'm puzzled,does this mean I have a bad Transfer Case since the actuator motor is working fine? If so,what is the recomended?
Ferne Singer
06-19-2019 11:12 AM
kwmamc
04-19-2012 03:57 PM
