Water leaking from roof console.
In the photos above, the item that gets forgotten..... As in the before and after pictures posted.... Is that small torx head screw that holds down the roof rack to the roof. If you pull it out and the threads are rusty, you found your leak. I used some Teflon tape, and covered the top the torx head with silicon.
Make sure you check out this thread:
https://www.hummerforums.com/forum/h...r-leaks-48951/
This is where my H2 was leaking and is totally overlooked!
Riccardo Soff
Jan 23, 2018 09:26 AM
Shayne100
Oct 2, 2014 05:54 AM
