water leak
Old Nov 15, 2011 | 11:07 PM
devanwon's Avatar
Question water leak
ok, i have a 2003, noticed that the windows were fogging up so that was interesting.... next day was vacuuming it and under the drivers mat was wet.
looked for leaks and couldnt find any, what or where could it have come from
Old Nov 20, 2011 | 12:42 AM
devanwon's Avatar
checked the body underneath, everything looks good there. maybe coming from the lights uptop and running down??
Old Nov 25, 2011 | 09:34 PM
devanwon's Avatar
Question
ideas, anyone??
Old Nov 26, 2011 | 02:52 AM
REBREATHER's Avatar
Hi
There are many places it can leak into water in an h2. The three orange lights on the roof produce new gaskets. where the wires go down through the ceiling from the two outer orange lights clean and add silicone. the 2 rails are screwed into the ceiling, it will enter water through screws to clean and seal with silicone. replace with a new door molding. water into the side window drops down to the cables coming from the side mirror and follow the wires that are attached clip at the bottom of the door and water comes inside the door and the water coming from the door and end up inside the door molding. remove the cover that is attached to the windscreen wiper on the right side will drain from the roof down if you have it. where you will also see a gap that is the fan. Extend the hose from the roof so the water can not get down into the gap to the fan. seal gaps with silicone are you doing all these things and I guarantee you that you have a 100% water tight hummer h2 in the rest of your life. is there anything you do not understand so you will email me and I'll try to explain myself better and send you some photos ..
best regards jens
My email address is
hummer_h2@hotmail.se
Old Dec 16, 2011 | 06:52 AM
paulw1029's Avatar
Yup. Once I added a small beam or silicone around my front marker lights it solved this problem I had.
Old Dec 16, 2011 | 05:35 PM
twinmill28's Avatar
Dude, I' m not sure it solved the problem so much as it hasn't rained out there in Arizona since, what, 1984?
Old Dec 17, 2011 | 09:23 AM
paulw1029's Avatar
I know right. We did get that 1/4 inch last week. First time I really noticed was the car wash.
Old Dec 22, 2011 | 05:24 PM
mrcool's Avatar
I just noticed my 07 H2 drivers side floor board is wet from a spray wash, drains appear open under marker lights ,but I will remove and seal with silicone( the light grommet) Door seals appear fine. where does the wiring harness come through the door post to interior? Just had windshield replaced could this cause problem? ant tricks there it was done by a pro company don't know if it leaked prior I haven't owned this long I hope I don't regret my purchase after reading some of the comments on this forum(my f 150 never leaked) any help would be great, thanks.
Old Dec 23, 2011 | 10:28 AM
paulw1029's Avatar
You won't regret your hummer. Just one of those things. I wouldn't trade mine. I have driven it through the lake, rockcrawl, even got it airborne and it still drives like new.
Old Aug 21, 2023 | 05:08 AM
MuseumMansDaughter's Avatar
Default hummer water leak,
im gonna keep a copy of all you said to see if it can help me figure out why my hummer is getting RUINED,, i mean ruined with water coming from i dont know where, but i do know the carpets and pads need out so they can dry well and not make for rust or mold, and i dontknow how to get the carpet and pad out,,, this is awful, floorboards have puddles of water,
Originally Posted by REBREATHER
Hi
best regards jens
My email address is
Propst72
May 5, 2016 05:08 PM
jdrew
Apr 4, 2008 12:19 AM
jstdoitt21
17
Jan 31, 2008 02:25 PM
clwilson
Dec 28, 2007 03:39 PM
JDJoe
Apr 28, 2007 03:20 PM
