-   Hummer H2 (https://www.hummerforums.com/forum/hummer-h2-8/)
-   -   under body rust/spray ?????? (https://www.hummerforums.com/forum/hummer-h2-8/under-body-rust-spray-32667/)
hmer 03-04-2014 10:01 PM
Had any of you guys ever try anything to spray rust spots under the H2 ???? If so please let me know what you use im planing on getting under my truck and take care of some of the rust ;-)....
Caraddict 03-05-2014 06:57 AM
I sprayed my whole under carriage with never wet, then went over with black paint as never wet finishes whitish film look...I still have some rust spots popping out after this winter...plan on doing it again this spring...
calif phil 03-05-2014 08:34 AM
I am going to do mine with POR 15 come spring time.
hmer 03-05-2014 04:34 PM
ILL start this weekend and do it slowly till i get it all done , it just looks like s_ht....
bapoptosis 03-09-2014 07:51 PM
Before you paint, go over all the rust spots with a "rust converter." I bought mine in the paint section at the auto parts store. It will chemically convert the rust, so you don't have to worry about sanding. I put it on every spring (it resembles water) with a chip brush. I have yet to paint anything, but I'm thinking I might touch everything up this year.
budryzer 03-10-2014 06:05 AM
Trust not rust
I have too much imo on mine as well. Picking it up from a dealer, it was black washed underneath. I knew it before I bought it but I'm surprised how much is actually rusted. I have done come already and I use the hammered texture rustoleum with an acid brush. It works but it does take a very long time to apply.
accely 03-14-2014 11:16 AM
I really liked using Rustoleum undercoating spray, goes on black and it's held up since last summer, definitely worth covering up all that ugly rust!
I've also used Raptor UPOL bed liner spray, basically it's DIY linex but it's alot more work ;P
man-of-war 03-15-2014 08:11 AM
1 Attachment(s)
Soon as it warms up I'm going to make a soda blaster and go to work on the rust spots under the hummer. I also plan on removing the plastic covering in the wheel-wells to spray with a rust protector.
Don't like the idea of the rust shops drilling into the side of the door to spray, so I'll also remove the door panels and spray it.
Last year September I mixed some diesel and engine oil and sprayed the under carridge with a gravity feed HVLP gun set on a cylindrical spray .
Attachment 12237
RARF 01-10-2017 12:14 PM
http://site-407957.mozfiles.com/file...29.JPG?1849794
Here you can check my website with all projects - rarf - Work projects
more info about under body rust treatment - RARF.lv
RARF 01-10-2017 12:46 PM
http://site-407957.mozfiles.com/file...54.JPG?1849747
