Twilight sentinel
Old Aug 22, 2020 | 11:21 PM
fastNYsix's Avatar
Default Twilight sentinel
Has anyone else had an issue with this sensor? My headlights are always on. If I shine a flashlight on the sensor, the headlights turn off. If I remove flashlight they turn back on. I’ve never had an issue with one of these sensors in any gm vehicle I’ve ever owned. Thanks
Old Aug 23, 2020 | 04:37 AM
oceanbrave's Avatar
Sounds like the automatic headlamp sensor (or ambient light sensor) is failing.
The plastic "dome" fell off mine, so I replaced it.
FYI it can be changed without removing the dash, but only" just" in reach (long thin arms required) just lower the compartment door, the sensor is "twsit-n-lock"
Old Aug 23, 2020 | 11:37 AM
I have a Blazer that is having the same problem. Unless the full sun is literally directly overhead and shining directly on the sensor they stay on all the time. Pretty much they might cut off 10% of the time during the day. Been meaning to order a new sensor for it, just have not gotten around to it yet and its been like that for a year.
Old Aug 24, 2020 | 06:58 AM
fastNYsix's Avatar
That's good to know, I don't want to pull dash trim again if I don't have to.
Old Sep 2, 2020 | 10:40 AM
fastNYsix's Avatar
Finally got this fixed. I tried a used junkyard sensor and it had the same symptoms. I had to buy a new one. The new one is slightly different in appearance but functions correctly. Ours is a 4 wire sensor by the way.
Old Sep 3, 2020 | 11:35 AM
oceanbrave's Avatar
How easy was it to access and replace?
Old Sep 3, 2020 | 01:59 PM
fastNYsix's Avatar
Easy, just reach through glove box like you said.
zx1100
Feb 25, 2014 02:50 PM
wfturner
Aug 6, 2013 02:55 AM
dwilton
Dec 15, 2012 09:37 AM
BIGT2148
Oct 28, 2009 07:50 PM
