-   Hummer H2 (https://www.hummerforums.com/forum/hummer-h2-8/)
-   -   Transmission (https://www.hummerforums.com/forum/hummer-h2-8/transmission-45195/)
Brunner Ferdinand Sep 29, 2021 04:14 AM
Transmission
Brunner Ferdinand Hello,
greetings to you,
My Hummer H2 Year of construction 2004 6.0 L
I rebuilt my gearbox and reinforced it.
Shifts flawlessly and great, but the converter lock-up lets my engine speed move up and down by about 200 rpm. Only when gliding.
The second thing is: if I turn up to 4000-5000 rpm, I have a short squeak when the 3 or 4 gear is engaged. Can someone help me there.
Thanks in advance.
:confused:
H2-SUT Oct 1, 2021 07:09 PM
Sounds like the fluid clutch in the torque converter may have a problem or possible lockup converter solenoid is not functioning properly. A transmission shop should be able to identify the exact cause using an OBD2 tool such as a Tech 2.
How clean is your fluid, that is a good indicator of your transmissions health. You need to get it diagnosed as soon as possible.
Brunner Ferdinand Oct 4, 2021 01:32 AM
Hi,The gearbox was rebuilt.everything was reinstalled.
It goes up to 4500 rpm like a new gearbox.No errors are saved.
