Transfer case pinion seal leaks
Old 05-05-2019, 06:51 PM
Sirina2's Avatar
Default Transfer case pinion seal leaks
I notices the cross member was wet with oil. I found the transfer case seal was leaking. Changed the seal and noticed the outside surface of the pinion was warn when I put the drive shaft back in. 2005 H2 has 115 k on it. Is this common problem? Thanks.
CarlosC
07-02-2023 10:46 AM
Wisconsin03H2
04-22-2019 09:40 PM
Paranormal
05-03-2016 06:15 PM
bigstick0000
11-28-2012 10:06 PM
rhino boy
01-12-2010 09:11 PM
Quick Reply: Transfer case pinion seal leaks
