Trailer brakes
You do. I went with the tekonsha prodigy p2. It has an adapter for your h2 that is plug and play. I had an issue with mine. it wasn't getting power to the controller so when I removed my fusebox under the hood to trace the problem I found a connector that came from the battery was loose. tightened it and no problems. works great. used it for the past two-three years.
I went with the Tekonsha P3 Brake Controller on my previous 2005 SUT and loved it .... I hauled a drag car and 4-wheeler back and forth to the track. It was an Ebay purchase specific for the H2 and came with a "plug n' play" connecter. It worked perfectly the first time out. I have not tried it in the '08 yet though.
Sadly, I sold the drag car, trailer and 4-wheeler in favor of the Streetglide in my sig. Hopefully, we will have a toy hauler soon for bike rallies and I will put the P3 to use then. We have to sell toys to buy new toys in lieu of adding toys.
I wasn't sure if the '08 fuse box plug was the same as the '05 ... thanks for letting me know it should work in the '08 as it did in the '05.
I have yet to find the 12V trailer power cable (w/eyelet) in mine though.
On the 08/09 The wire with eyelet under the hood is kinda hidden. It is tapped down on the wire harness feeding in/out of fuse box on the motor side. Mostly black wire with red line... making that much harder to see but it is there. I believe it is folded back on its self.
