sunroof
Old 05-18-2018, 12:51 PM
jd1368's Avatar
Default sunroof
So i added a light bar to my front roof rack, and to get everything to fit right I had to take off the wind deflector over the sunroof... unfortunately now I have a bit of a leak and the noise of the wind is incredibly loud so I want to put one back on... problem is there were 2 screws and two clips that held it on and I misplaced them. Anyone know where i can get a new windscreen with the proper bolts and clips?
Old 05-20-2018, 08:19 PM
mcioci's Avatar
Check eBay. You can always buy an aftermarket one that gets installed by double sided tape.
Old 05-21-2018, 12:22 PM
LoJac963's Avatar
^correct, you can find the mounting hardware on ebay/amazon relatively cheap. Be warned though, the wind noise will probably still be there due to the light bar even after reinstalling the air deflector.
Old 05-21-2018, 07:37 PM
mcioci's Avatar
move your roof rail with lightbar behind the sunroof. I did that and no wind noise
Old 05-22-2018, 07:50 AM
If you just want the clips....
https://www.ebay.com/itm/332179524584
That particular seller has quite a number of original new Hummer parts too by the way.
Old 05-23-2018, 07:38 AM
mcioci's Avatar
that seller blocked me on eBay because I purchased the rear molding for my SUT and it came all scratched up so I sent it back for refund and he or they got pissed
Old 05-23-2018, 07:22 PM
hummer_on_fumes's Avatar
Where are you located? I took mine off when I added my light cage, I doubt I'll ever put it back on
03WhiteH2
03-20-2024 09:30 AM
justinroberts31
01-03-2022 11:33 AM
H34 pleasure
44
05-04-2007 04:17 AM
MJS H3
07-05-2006 11:09 PM
iruffneck
17
03-04-2006 01:33 AM
Quick Reply: sunroof
