Service 4wd
Old 11-05-2016, 09:18 PM
HUMTECH's Avatar
Also if you installed a new shift motor it needs to be torqued correctly. Inproper torque on the mounting bolts can cause binding
Old 11-06-2016, 10:12 AM
Hitmanpty's Avatar
Ok i will try to pull out the motor today. I will try to shift manually.
If the TC is not aline with the motor. How i go about sincronizing the shift
Old 11-06-2016, 10:41 AM
Hitmanpty's Avatar
Im starting to belive. The problem is proper aligmen seting betewn tc motor and tc shaft.
I need to know how to align the 2 of the correctely. I dont now how
Old 11-06-2016, 02:12 PM
flyday58's Avatar
Seems like you could either plug the motor into the harness and use the 4WD switch to line it up, but Humtech says you should be able to move the transfer case gears with a wrench to get it aligned. I never tried but he says it should move.
Old 11-06-2016, 02:59 PM
Hitmanpty's Avatar
With the tc motor out.
How do i go about moving the tranfer cast small shaft
Wich way is 4wd low or 4 wd hi. Conter clock wise or clock wise
Do the engine have to be runing
If i just use the switch with the unistall motor but plug in
Will this take care of the ajustment?
What i need is a prosedure. To guide me step by step
Old 11-06-2016, 07:16 PM
HUMTECH's Avatar
Don't plug in the motor and turn it with switch on dash if not installed. This can cause motor to over rotate and possibly damage it. If you had it bolted on the transfer case it was obviously aligined or it would not bolt on
Old 11-06-2016, 07:18 PM
HUMTECH's Avatar
You should be able to rotate the shaft with a wrench or vice grip, if it wont move there is an internal problem causing the no shift.
Old 11-09-2016, 11:39 AM
Hitmanpty's Avatar
Hi every one here is my update.
I did pull out the motor and and push the dash butons to see if move. Sorry Humtech i read your messege to late
Any way like i say i did test yhe motor and i get zero move. The motor is not respondong in anyway.
Since the motor is new and the switcj is also new. The only posibility I can think off the the module under the steeing whell.
Please advice
Old 11-09-2016, 11:15 PM
Hitmanpty's Avatar
Any body????
Old 11-10-2016, 11:15 AM
flyday58's Avatar
Basics: check fuses. Look for broken wires, loose plugs. Do you have the "service 4wd" message? And how long have you owned this truck? Can you post a video or your lights and dash when you try to activate the other positions?
Quick Reply: Service 4wd
