Sealant for Hummer H2 Rear License Plate Pocket
Old Nov 8, 2023 | 07:58 AM
Brunob00's Avatar
Default Sealant for Hummer H2 Rear License Plate Pocket
I am deep cleaning my H2. Pulled the rear tailgate apart to get all the dirt and dust out, and install some sound deadener. The license plate pocket has a flexible gasket / sealant around it from the factory to keep the water out. I would like to reapply new sealant to get a water tight fit. It is tacky, stretchy, and a bit sticky. It can be pulled and molded and is slathered around the handle to keep the water out. Anyone know what sealant GM used? Ideas?
Old Nov 8, 2023 | 10:02 AM
sounds like butyl same stuff used to seal the door panels.
Amazon Amazon
my 03 did not have any sealant or gaskets. maybe they corrected something later in production or some one was chasing down a leak.
Old Nov 8, 2023 | 10:13 AM
Brunob00's Avatar
Maybe the sealant was added to later H2s... I know they come like this from the factory for the 06-09 H2s. This is what it looks like on the back...
Old Nov 8, 2023 | 01:41 PM
Measure it and replace with a waterproof self adhesive neoprene/rubber
Marine Weather Stripping Marine Weather Stripping
. After install water it & check for internal leaks.
Old Dec 22, 2023 | 01:56 PM
Brunob00's Avatar
I ran across this product from DAP called Seal N Peal Removable Caulk. Anyone have experience using it with any type of automotive trim? Appears to be safe on paint.
Old Dec 22, 2023 | 02:01 PM
did you ever click on the link i posted above for butyl tape? i am sure there is a size that will fit your need.
Old Dec 22, 2023 | 06:04 PM
Mark R's Avatar
[QUOTE=bronxteck;405698]did you ever click on the link i posted above for butyl tape? i am sure there is a size that will fit your need.[/QUOT]
Yep I'd go with the Butyl... Or non hardening RTV Black sealant. Bu Butyl would be my first choice.
Old Jan 9, 2026 | 11:09 AM
Brunob00's Avatar
@bronxteck @Mark R - I picked this project back up, ordered some Butyl Tape and I can confirm that it is pretty close to the GM OEM gasket on the license plate pocket. I say "pretty close" as the butyl tape I ordered is more tacky than the GM OEM gasket which can be easily removed from the painted surface. Easily applied and confident it will keep the water out... not sure how easy it will be to remove!
Old Jan 9, 2026 | 02:26 PM
Mark R's Avatar
That's good. To cold to do anything here in Joisey..... Need to take care of a off road lamp failure. two of my 4 stopped working .They are on separate circuits with relay activation from the stock Hi Beam switch. I'll have to wait till warm weather before I get into it. They are made by "PIAA" good stuff.
Sticky and Tacky is good for keeping water out. Should work fine.
BillSmith
May 14, 2020 11:21 AM
ak47dennis
Dec 2, 2013 09:44 PM
BIGT2148
Aug 4, 2010 05:28 PM
MTHUMMER29
Mar 6, 2010 11:54 PM
JTummer
Oct 1, 2008 09:24 PM
