Rear hatch wont open, what now?
Threw some stuff in the back of my '03 H2 today and when I got home the handle no longer will open the back hatch. Am I going to have to somehow take the huge panel off from the inside in order to reach the handle mechanism to open it and probably fix it?
Veteman40404... How did you figure out how to remove the back hatch panel? I only found (3) visible screws?? Two along the bottom (near two hooks), and one under the strap handle. Do you just PULL on the panel to remove it after removing those three screws?
Did you use a manual or diagram?
Thanks for any help. I too need to remove my back panel. Thanks!
You need to remove the screw from the pull handle to give the cargo trim some give then pull it away from the window from the top to get your arm down there. Grab the cables and pull up on them to release the locks. Once the hatch is open completely remove the trim piece and replace the actuator and/or cables.
cybordolphin
Apr 8, 2010 09:07 PM
