rattling in headliner over 70 mph?
What two black side pieces are you referring to? Mine is sooo damn bad that I can't hear the radio. So bad, I'm about to trade it in. I can't find the cause. I've added in some gasket materials where I thought I found some rubbing, but it didn't help.
I had the same problem over 65 M.P.H. I cured it with a thin bead of clear silicone at the sides of the windshield under the black rubber, I thought it was the roof racks for the longest time and finally removed them only to find out it wasn't. DOH!
That makes sense. I know it's coming from something that is very close to the glass. It sounds like something rattling on the glass on the passenger side. Thought I found it yesterday and installed some gasket material with adhesive and put it back together only to find out I had only quieted it down some. I'm going to put the clear silicone in the corners. That sounds like it would work. Damn sure can't hurt anything. It's bad enough like I said, that I was just going to go get an '08 or '09 and deal with it. Only have 49,000 on this one and hated to do it. May do it anyhow if I can find a good one.
2006 post of mine on the repair of the A Pillar Molding. Hope it helps some here.
http://www.elcovaforums.com/forums/s...ad.php?t=16756
Ed
Ed
