Leaking Transfer Case
I found out that the strange rattling (pennies in a jar) noise, is coming from my transfer case, which is leaking.
Has anyone else had this problem with their H3, who could help me figure out how to fix it? I don't want to take it to a mechanic and spend hundreds of dollars just to open it, but I will if I have no other option.
Thanks guys.
Thanks guys.
If you end up needing to replace the transfer case, you might want to get the "adventure" 4:1 crawl gear one. It is actually cheaper than the 2.x:1 - and is a drop in replacement. FYI my own thoughts on rear diffs - if my rear diff ever blows up I would get the e-locker version for $200 more. You can drop in a e-locker rear diff w/o any electrical connections and it will work just like the open diff. Then just need to wire it up later to have a locking rear diff.
smileynialley
03-25-2013 05:19 PM
smileynialley
03-22-2012 12:44 PM
HummerH2
10-27-2011 07:22 AM
07-19-2006 03:05 PM
