Part number help for bolt
Hey guys I need help with a part number for a Bolt & Nut for my H2. It's the bolt that secures the torsion spring crossmember to a bushing bracket on the inside of the frame rail. I've attached a picture . I looked through every Hummer parts diagram I could find and I can find the crossmember but I can't find the part number for this particular bolt, it's stripped so I can't get my H2 back together. Help appreciated . I tried to match it up at the local specialty nut and bolt shops but they're all closed because the Covid, so I'm going to have to mail order one https://cimg3.ibsrv.net/gimg/www.hum...09a5f05eba.jpg |
That will throw you off, asking about an H2 part but showing the part in the center console of an H3 🤣
I would try going to the dealer, I’ve found that they have a much more complete parts diagram in their system than anything you can find on the web. iirc the door panel clips are dealer parts diagram only for example. |
I confess!! I currently have one of each- I have a 07 H3 that's up to 170K now, so I found a low milage 04 H2 to eventually replace it with.. I tried local chevy/GMC parts guys but they are also currently closed..
That’s odd, I went to the dealer yesterday and had my brake fluid changed, dealerships are considered essential, not sure why they would be closed.
just go to a hardware store and have it matched up. there is nothing special about it other then maybe being a grade 8 bolt.
Class 10.9 - M10-1.5 |
| All times are GMT -5. The time now is 01:41 AM. |
