One taillight don't light up
Hey I just bought a 2003 Hummer h2 one taillight was out I figured it was the led got bad so when I bought the car I bought new led brake lights but same thing passenger side brakes turn signals and reserve but doesn't turn on when I turn on the lights please help
Do you have 12 volts to the light?
Check the socket. |
Originally Posted by wpage
(Post 395022)
Check the socket. |
Does not matter what type lights. No power no lights.
If its not a wiring problem. Start checking your fuses. |
(Post 395024)
Anybody that owns a vehicle more than 10 years old should be familiar with electrical issues, how to trace them, and what to use to get things working.
https://cimg5.ibsrv.net/gimg/www.hum...258a349858.jpg |
(Post 395029)
check the rear chassis grounds for corrosion. should be one one both sides near the body bushings.
If you read the threads on this forum, you will find out very quickly that the H2 does not like certain types of LED lights. These cause all sorts of mysterious electrical gremlins.
So, put everything back to stock, see what happens. Then start substituting LED lights back in slowly. You can do it the harder way if you want, but that is what I would do. You have some serious electrical problems. This is more than a bad connection or ground. Too many issues for that. |
(Post 395035)
| All times are GMT -5. The time now is 06:31 AM. |
