Oil leak
What a month . First the coolant leak ... Now oil leak
Well , weird is the oil leak is on the passenger side . I don't think any oil lines runs on that side My first impression was the tranny lines leaking but after measure the levels oil was a little low while transmission fluid is fine Any idea where could the oil come from Thanks |
H2miami, have the same side leak, but mine was found to be the pass,side diff. seal that is leaking, you might look at that.( cowboy
H2Miami, Have the same pass side leak, but mine was found to be the pass, side diff, seal leaking, might check that out. Cowboy
My guess maybe it from A/C Compressor since it is on passenger side
