Next H2 up for Duramax
what do you use to replace the lower part of the body bushes when they are rotted out? i saw you mention pucks do you mean hocky pucks with a half inch hole drilled in the center? i know the old timers used to use them before the silicone ones where available as they are made from vulcanized rubber and are about 1" thick and 3 inches wide.
I put a one inch puck on top for a one inch of lift for space issues. And for front end with the Duramax intercooler radiator fittment. It takes a lot of front end fabrication away and saves time. The bottom bushing I just take off donor truck if I have a bad one. They make replacement bushings u can buy. I’m sure the puck would work great on the bottom with some drilling.
