-   Hummer H2 (https://www.hummerforums.com/forum/hummer-h2-8/)
-   -   New Spicer U Joint Review (https://www.hummerforums.com/forum/hummer-h2-8/new-spicer-u-joint-review-46905/)
Vax1op369 Apr 23, 2023 09:43 PM
Hello Hummer team, Installed Spicer U joints. SPL30-1350XC. Around $60 a piece now. Wow, The shifting and ride quality was such an upgrade. Super smooth. Couldn't even feel the shift ,buttery smooth. Working on a youtube video for install tips. Front and rear are both y
the same , 2005 H2
https://cimg3.ibsrv.net/gimg/www.hum...0e489450b.jpeg
https://cimg4.ibsrv.net/gimg/www.hum...77dbbd30d.jpeg
https://cimg5.ibsrv.net/gimg/www.hum...484ef54b8.jpeg
calif phil Apr 25, 2023 08:04 AM
Great choice, Spicer has always been the best.
ejsmall Jul 11, 2023 11:25 PM
Vax1op369, I purchased Spicer front and rear shaft joints, but Im told I need to have the shafts balanced with the new joints installed. I don't understand why need to balance as the shaft is balanced and new joints must be within some balance tolerance. Any recommendations?
calif phil Jul 12, 2023 06:34 AM
No need to balance after a U joint replacement, did you mark the driveshaft to the differential yoke and put it back in the same orientation? If you didn't and do feel some imbalance, you can unbolt the driveshaft and rotate it 180 degrees.
Vax1op369 Jul 12, 2023 11:40 AM
Agree with Phil, no need to rebalance. Especially if Shaft is coated in surface rust. Will never be able to have it 100% Do the best you can attempting to mark it and putting the yoke back into transmission. I haven’t had any issues with mine since installing new U joints.
Doc Olds Jul 12, 2023 02:44 PM
This is quit the spicy review! :eek:
Of Spicer, that is. :D
Spicer is the way to go.
finall Jul 12, 2023 04:23 PM
How do you know when it is time to replace these?
hummerz Jul 12, 2023 06:52 PM
ejsmall Jul 13, 2023 09:21 AM
Thank you Phil and Vax. This all makes perfect sense. I think the guy doing my build is just being careful to protect himself from complaints. He recognizes that I'm very particular about how everything looks and runs. I did get plugged into a local machine shop which refurbishes drive shafts. They are going to refinish and apoxy the shafts, install the Spicer joints and balance them. Quote is $300. Im going to do this. Given the scope of what is being done to the truck, I will like to eradicate the Maine rust from every part.
Vax1op369 Jul 13, 2023 09:32 AM
Ill work on getting the video uploaded to youtube if you would like to do the install yourself.
