-   Hummer H2 (https://www.hummerforums.com/forum/hummer-h2-8/)
-   -   NEED Instrument Cluster for 2004 Hummer (https://www.hummerforums.com/forum/hummer-h2-8/need-instrument-cluster-2004-hummer-45607/)
majj35 Jan 31, 2022 03:02 AM
Hi I have a 2004 Hummer H2, I live outside the U.S. I've been having issues with my Instrument Cluster, and the dealership can't fix it and needs to be replaced. The issue is, the part number I have has been discontinued (15134729) so I need to find out which other ones would fit from the following:
  • 15199643 / 15179500 - This
  • 145396 - This
I've asked sellers on eBay who list clusters for 2003 and 2005, and they say it should work on mine... the dealership says they cannot gurantee it would work as they only go with the cars' actual part number. Can anyone let me know if either would fit? (ps. I can't send mine to be fixed, I live abroad.. shipping it all the way and back + repair would cost the same as getting a ready one from eBay) Thanks
oceanbrave Jan 31, 2022 07:36 AM
majj35
may I ask which country you live in?
majj35 Jan 31, 2022 08:00 AM
Originally Posted by oceanbrave (Post 391397)
majj35
saudi Arabia
bronxteck Jan 31, 2022 10:36 AM
for my 2003 h2 i was able to use the cluster from a 2003 chevy taho. the housings are different but the board inside fits in the hummer cluster. i also had to transfer the EProm chip to keep my mileage
oceanbrave Jan 31, 2022 11:09 AM
Would be interested in a scrap or broken cluster, please let me know if you have one before you bin it....
finall Feb 4, 2022 12:37 AM
Dealerships can not fix clusters. Do not even let them try. This is a very specialized service.
This is a relatively simple solution for you Saudi guy.
There are numerous companies that rebuild instrument clusters in Canada and the USA. I think there is on in Calgary, Alberta from what I remember. Sure that they are scattered all over the place. Likely more on the East Coast, closer to you in the USA or Canada, as larger population there.
Use your powers of google and you will have your answer in minutes. Check eBay, Aliexpress, Amazon, etc. also for companies offering this service.
When we purchased our USA H2, they sent the cluster out to get changed to Kph from Mph, including odometer change to km, to a place in Calgary 1000km away. Took 3 days. No problem.
Be prepared to be without the cluster for about 2 weeks, including shipping time if you FedEx. Work takes about a week, sometimes only a day or two if you are in a rush.
Few hundred $$ will get it repaired.
zenith Feb 8, 2022 04:32 PM
There is a company that sells outright new/rebuilt clusters with your choice of options for H2's GM's:
https://www.fixmygauges.com/h2-hummer-clusters.html
