Moisture/defrost ?????
We've had our 06 H2 for a couple of months. Now that winter is here, we're using the defrost to clear the windows more. Just wondering if anyone had a similar experience with a high level of moisture in the winter?? The more people inside the more the windows are fogging. It's worse in the passenger and third row since there are no direct vents.
In our Acura, the AC automatically turns on every time we hit the defrost....just wondering if there is a special trick that may help since it's just our first winter with the beast.
THANKS!
THANKS!
RE: Moisture/defrost ?????
mine seems to do the same thing...but I also had a leak up top, which caused excess moisture to build up in the truck. You may want to check your marker lights and make sure they are not leaking.....if they are use some black silicone, and that should take care of it.....
nickoliboz
11-29-2017 08:49 AM
Hooty-Hoo
09-02-2011 11:26 PM
