MAF required for a new Volant CAI?
I am looking to purchase a new Volant CAI for my 05 Hummer H2. Looks like there are two types available, with and without the Mass Airflow Sensor and the difference in price is almost $350. Can I just use the MAF from the old stock intake assy or do I need tp spend the additional $350 for the MAF that comes with the volant kit? Thanks!
The difference is amazing, much quicker off the line and mileage went from 12.2 mpg to 13.3 mpg.(city) I am also running with a Helix T.P. throttle body spacer on 325/60/20 Terra Grapplers. Unless you did a lot of modifications,stick with the stock one. Hope this helps.
2003-2006 6.0 Hummer H2 MAF Sensor - Black
Fits 2003-2006 6.0 Hummer H2 only
Direct OEM replacement, won't void your factory warranty
Improves mileage and throttle response
Chassis dyno proven to add 8-25 horsepower (depending on application), 60% airflow increase over stock
Improves performance from 2,000 rpm to red line
"Truly Calibrated" on our in-house MAF Dyno and Flow Bench to optimize performance for YOUR specific application
Compatible with most electronics and aftermarket bolt-on performance equipment
Installs in 10-15 minutes using basic hand tools.
they sell around $300 but u can have this one for $170 shipped to ur door
this is my first post here, but u can find me with the same screen name on www.corvetteforum.com and check my feedback on other sales.
thank you all...
HummerH2
03-20-2011 03:00 PM
nodnarbedge
01-30-2009 04:03 PM
jng1226
06-28-2007 02:30 AM
