Lower control arm mounting holes worn
Hi everybody. I have had some noises in my front end, and from what I can see the only thing that looks worn are the mounting holes for the lower control arms. Both of the rear holes show rust and I can see the mounting hole outside of the bolt, so I know that they aren’t mounted solid as they once were. Does anybody know how to go about fixing this? Has anybody had this issue before? I am thinking that I’ll need to weld metal in place and make new holes, I feel that if I just go with putting some thick washers I will still get some play, but if anybody has had the same issue and came up with a fix please let me know. Thanks.
Post up some pictures of the issue so we can take a look. I've never messed with my lower control arms, I am assuming you are talking about the front and not the rear trailing arms?
https://cimg0.ibsrv.net/gimg/www.hum...92cac97b6.jpeg
Passenger side lower control arm bolt https://cimg2.ibsrv.net/gimg/www.hum...d6f1a2622.jpeg Drivers side lower control arm bolt Here are pics of both sides. The passenger side looks worse. They are the front lower control arms. Thanks for any suggestions. |
yup there is no quick fix for that. you will need to weld on some washers or a plate. unless you can find some sort of metal bushing to fill the void. if the bolt can come out of the other side with no issues you can also weld the nut permanently to the frame.
Lower control arm bolt hole
(Post 360161)
can I just loosen it up (or tighten) and weld where it sits? |
Originally Posted by niced
(Post 406731)
is there a very specific exact place This nut needs to be before welding or is it more so the bolt doesn't move itself when tightened?
(Post 406731)
can I just loosen it up (or tighten) and weld where it sits? To answer your question. This ain't nuclear submarine engineering, weld it anywhere so long as the bolt gets through and has no wiggle room. Weld the nut to the frame = no wiggle and you can still remove the bolt any time for service. Do not weld the bolt. |
