larger battery that is more readily available?
hey guys its time for a battery change and here in canada its harder to find the group 79 battery that comes stock so i wanted to ask if there is any larger battery that i can fit into the battery holder while being readily available so i can save a little on cost.
the ac delco 79pg is $270 here in canada and i wasnt happy with how long my old one lasted so i dont want to go with them again
thanks
thanks
Stick with the 79 and find a different brand---> EastPenn
Who Makes ACDelco Batteries? Middle East Battery Company manufactures batteries for General Motors parts supplier ACDelco. Middle East Battery Company is in Saudi Arabia; Wisconsin-based Johnson Controls owns 49 percent of the company and investors own 51 percent.
ahh darn yeah i think i will probably have to do that.
correct me if i am wrong but a larger battery will have a higher reserve capacity and higher cca right?
i was wondering what are the negatives of lets say running a group 78 side post with 800 cca? it seems like i can save $140 if i run a group 78.
regardless if the battery is side or top post, i can just rewire the battery cables and change them to top post no?
however i am open to running something larger too but it cant be near obselete like a group 79.
being in canada sucks
thanks for all the help!
correct me if am wrong but it seems like the group 78 is smaller then the group 79 but has more cca?
i thought the bigger battery will have a larger cca and larger reserve capacity or does a bigger battery only have higher reserve while cca is dependant on quality and composition etc?
i have used optima yellow top AGM type D34 with post to side post adapters with no issues. i have had that battery since October of 2014 no issues starting the hummer during the winters here up north.
