Interior Trim painting witth chalkboard spray
Old 01-21-2019, 02:11 PM
Hbrezzi's Avatar
Default Interior Trim painting witth chalkboard spray
I have looked all over Panama for a spray paint that could match my black interior trims.
I decided to try the rust-oleum chalkboard spray paint since I really liked the color.
I am impressed with the results. It has a “tough” matte finish that blends in very well with the original colors. It also dries very quickly. For this test I didn’t use a primer but I’ll definitely use it.
I tried it on the driver side fuse box cover and vent trim. What do you think?
Old 01-21-2019, 08:39 PM
hmer's Avatar
Im looking to do the same thing thanks for posting this ...
Old 01-22-2019, 07:43 AM
calif phil's Avatar
Great job, it looks awesome.
Old 01-22-2019, 11:59 AM
LoJac963's Avatar
Interesting, did you remove the rubberized coating on the parts before spraying?
Old 01-22-2019, 04:39 PM
Hbrezzi's Avatar
I used thinner only where the coating was really peeling off. Then 200 wet sand paper and finished with 1200.
Of course, before painting it, I washed it with dish soap.
What I’m seeing is that I need to find a good primer that can fill in the imperfections. I did not sand ithe plastic down to the core as 1. I’m lazy 2. Don’t have much time. A professional would most definitely roll his eyes 👀
I am still looking for a good matte clear coat spray for the finishing touch.
Guess you can use paint remover but it might be too harsh on the plastic?
Sanding with 200
Finishing with 1200
One coat of primer
3 coats of paint
Old 01-23-2019, 11:34 AM
Hbrezzi's Avatar
Last night I finished 2 more pieces
Before
After
Old 01-23-2019, 12:51 PM
hummer_on_fumes's Avatar
It looks amazing! It's hard to tell, what color is your interior plastic? Is it the metallic gray'ish color? That's what mine is and I've been looking for a good color to match. I want to redo my plastics one day as they're peeling as well. If you repaint the plastic around the interior door handles, let me know how you got them off.
Old 01-23-2019, 01:35 PM
Hbrezzi's Avatar
Thank you!
Here are some pictures of the painted parts vs the original. A bit hard to reproduce in the pics the original panel colors but, I hope it gives you an idea.
Unpainted door handle
1. New 2. Original
1. New 2. Original
All new painted trims. Same color but nice contrast
1. New 2. Original
I still have not worked the passenger side which still has the original flaking paint
Old 01-25-2019, 04:57 PM
Sirina2's Avatar
Default Nice trim rehab.
Want to do my center panel in dash this spring. Anybody try matching this panel it to exterior color? My 2005 H2 is repainted with 2006 Audi Pacific Blue.
Old 01-25-2019, 06:28 PM
I've seen lots where someone had a body shop paint the pieces to match the exterior.
Quick Reply: Interior Trim painting witth chalkboard spray
