interior trim over RR wheel where buy?
I just bought a 2008 H2 with black interior the large plastic interior trim piece over the right rear wheel is broken- where can I buy that ?
Thanks Bob |
Did you check Walmart? :rolleyes:
Discontinued Product |
Cute, just show it to me like it is easy to find. But thanks for the part number. Is there any good salvage yards that specialize in H2s ?
:rolleyes:Ever heard of EBAY? Click on the items, and you will find many salvage yards, showing the "donor vehicle". Find a listing with a donor '08-'09, then simply "Contact Seller", and ask if they have the part you need.
Current used listings @ 36,117 for the '08. https://cimg4.ibsrv.net/gimg/www.hum...6eb2b51259.jpg |
Curious, post a picture of your current quarter trim panel.
This interior trim is all discontinued and getting rare to find.
Can you solvent-weld it together? Most of this type of plastic interior trim can be welded together with Toluene or MEK. Even broken tabs can be melted together. Only certain types of plastics can be done this way, and you have to test. (For example, nylon can only be fused together (melted) with a heat gun or torch.) The other option is plastic epoxy putty available in plumbing stores and Home Depot. It can and does work very well on certain plastics. I have done this more times on plastic items than I like to remember. Another alternative is a body shop that specializes in plastic component repair. They are hard to find. "Broken" how? Show us a photo. |
they also have hot staple kits like this one https://www.astrotools.com/hot-stapl...ic-repair.html
Originally Posted by BobSoCal
(Post 385400)
(Post 385400)
https://www.ebay.com/str/jandjautowr...3&_dmd=2&rt=nc |
YES my bad, frustration but I looked on Ebay as I always do. but did not have the part number and I do appreciate the part number- that is a real benefit to a forum like this Hummer one, shared experience. The guy that I just bought this H2 from appears to have thrown the piece out so I can't glue/epoxy it in.
THANKS ALL for sharing your experience I am enjoying my H2 |
