Hypertech programmer
Old 09-20-2012, 09:09 PM
honda400ex2003's Avatar
i have everything in my sig.
full magnaflow, ceramic headers, fipk k&n full intake, and a 91 octane tune.
the only thing i cant do is adjust for my 44s. it doesnt go high enough to do that.
steve
Old 09-21-2012, 02:42 PM
bflorin's Avatar
Originally Posted by Christopher Brock Cinematographer
Pretty much anything that communicates with the H2's computer has to be disabled during programming. On Star, any after market electronics, etc..
My programming failed the first few times until I figured this out
You know how many other modules are in the truck that are all actively communicate w/ it? If thats the case your going to have to pull alot more fuses than that. I've never had any problems w/ my hypertech.
Driver door, pass door, Instrument panel cluster, Airbag module, BCM, Radio, Bose amp, HVAC controller, onstar module, air suspension, generator battery control module....name a few off the top of my head.
Old 09-21-2012, 02:48 PM
bflorin's Avatar
steve
There is a converter box you plug inline w/ your tranny that will set any ratio you could ever need. Its about $175.
Google Electronic Ratio Adapter (ERA)
4L60E Parts List at PATC Raptor Transmissions
Old 09-21-2012, 08:23 PM
thanks for the link, i have to buy one of those so i can finally get it right. I was pretty bummed when i got my super chip and couldnt adjust it far enough. I was told that it went to 55s so on a recommendation i purchased it.
other than the tire size though, the tuner has been great. plug it into the obd-2 port and turn the key on, choose the tune and parameters, send it to the ecu, let it do its thing with the reflash, turn the key off. it takes less than 5 minutes start to finish so its pretty nice to switch to something like tow mode when needed.
steve
Old 09-21-2012, 09:19 PM
bflorin's Avatar
steve
You know there is a button on the dash for that....
Old 09-21-2012, 09:22 PM
but you dont get to utilize the tune and shift points throughout the whole power band and such when using the button on the dash.
the button just takes it out of OD, the tuner keeps all of your settings for the mods you have and gives you a performance tune to go along with the shift points and taking it out of OD.
steve
solarflare
07-15-2008 09:29 AM
gilby2727
02-25-2008 07:07 PM
h2dan
16
09-04-2007 10:26 PM
kseaman
07-21-2007 05:04 PM
03HUMMERH2
07-06-2007 09:10 PM
Quick Reply: Hypertech programmer
