Hvac Actuator relearning fixed
Well again the passenger side was blowing hot air after battery was depleted for not using the truck more than a week
Got a new actuator . Installed . Did the relearn procedure but nothing Did it 3 more times . Nothing Then I remembered last time I leave the battery disconnect for the night So I disconnect the both wires . Leave for 12 hr . Connected back Turn ignition on for 4 min . Dont touch the Ac controls Turn ignition key off for 15 sec Start engine . And bingo it was fixed So in my case disconnect the battery for 12hr was what did the trick Hopefully this helps Btw the original actuator wasnt bad . Just miss the program |
