hummer h2 drl
Question: i got a 2004 hummer h2 & im having problems with my DRL's i switched them so they can turn on with the driving lights & put green bulb in the fog light but for some reason it keeps turning on / off by its self in a pattern. What could be the problem ? I was thinking it was the watt on the bulb that wasn't enough but idk please help !!!!! :(
Why not to instal the oem bulb back and see what happen ... If that solve the issue then you need another type of bulb
Not to mention green bulbs from the front in most states are illegal. Something to check into as well.
Originally Posted by LoJac963
(Post 314527)
There's a guy out by me with green halos in his charger, headlights and fog lights. I can't believe he hasn't been ticketed. When HID's first came out years ago I retro fitted a vehicle of mine and the cops constantly pulled me over with fix it tickets....
Oh yea same happened with me when i first put HID's on they would constantly be an ass about it
assuming you running the relay by jumping the DRLS RELAY with 10amp diode,please check this diode,maybe it need to replace. did happened to me bfore.
